Hello guys! I have following problem(Currently on OpenCities Map Advanced update 16 [10.16.2.14]):
I have a cell, containing single subelement of type line. (click on pictures to see them in full mode)
At this stage everything is okay, scale of the cell is 1 and linestyle scale of the line subelement is also correct(1).
However, when i change a scale of my cell
Linestyle scale of my line subelement changes as well
I want it to stay 1 and to not be influenced by scaling of its parent cell.
The same behavior on V8I works fine(same rsc for linestyle). Am I missing some kind of settings? I checked also the linestyle scale on my model properties, but it is showing global linestyle scale which is set to 1.
Thanks in advance for any kind of responses!
