Hi all,
This issue has been bothering me for a long time. Today I tried again with brand new OpenCitiesMap Ultimate Update 17 (10.17.01.29) and the situation is as follows:
CASE 1 - Connect to WFS service
Tried to create connection to WFS service - successful! read layers well, I can manage connection properties but didn't recognize geometry type for a layer (manually defined as Polygon)
Tried to Query data from WFS service - unsuccesful! with message "Feature type:CadastralParcelType unknown"
CASE 2 - Import from WFS service
Tried to create import - succesful! read layers well, I can manage connection properties but didn't recognize geometry type for a layer (manually define as Polygon)
Tried to Import data from WFS service - unsuccesful! with message on image
Both test cases are in attached zip file
TEST OSS WFS servisa u novoj verziji Map-a update 17.zip
WFS service working fine on QGIS
P.S. Created SR #7001508279
Thanks in advance
Mladen
