Hi all,
Maybe I'm doing something wrong....
In the XFM schema I have properties, instances and values as shown in the Data Browser. Some of properties are defined in the XFM shema as ComboBoxes with attached domains (marked as red), and one is a TextBox (green).
When I try to filter the values form the TextBox properties everything works fine
The problem is when I try to filter the values in the ComboBox properties that store the values as integers. I cannot filter by value (integer) or name (string) of a property. (VNCO: 0 = Unknown; 1= Direct mapping...)
With ComboBoxes who store values as a string everything works fine... (F_CODE: AL070 - Fence; AL260 - Wall, etc.)
XFM Schema: (contact me)
Many thanks in advance.
Kind regards,
Mladen
OCM Ultimate 10.17.01.29
Hi Madlen,
I submit your case to Development team. The only workaround I have to suggest so far is to work with String value type for combobox. I understand this is probably not sufficient and this is why I have reported to our team to be fix. Sorry for inconvenient. Regards,Sebastien
Thanks Sebastien,
String type of property instead of integer is not an option because thee data model is a valid national standard and I can't change anything.
Anyway, thanks for the suggestion and the Service request.
