Hi all. Me again
I've seen few posts about same issue but it seems that deficiency is still here (e.g. link link link).
What I want is to create PBS or something similar that consider value in ANGLE property of the feature and apply rotation angle from that value to Text and Cell features.
1. attempt
I know... the solution is terrible but just want to check does PBS work on Angle and Color of the element. PBS for Color is working fine (and checking Criteria also) but for Angle it doesn't work.
2. attempt
Maybe it will work - NO!
3. attempt
Tried with Item Types to see does we can relate angle of the element with property - it can only as Item Types, but I need similar functionality with XFM feature property.
Does anyone have any ideas because I'm ran out of it.
Thanks in advance.
Kind regards,
Mladen
OCM Ultimate 10.17.01.29
Hello Mladen, Worth knowing is that the value (still) needs to be set in Radians. That notwithstanding, I've tested with the geo_example.xml 'Lot' feature, to no avail. It would seem to be a bug, and so we've filed 1072839 XFM Symbology Text feature Angle is not consideredPlease file a service request at your earliest convenience and mention this defect #. We will associate the defect to the SR for tracking and notification.
thanks.
Nels
Hi Nelson,
Service Request #7001535114 is filled and I've attached test schema. Also, I mentioned defect # in request.
Thanks for help!
