better late, than never! After using GeoGraphics for some years, I just started to try out something in Bentley Map (v8.9.4.173; +MicroStation v8.9.4.88). Fighting with my old topology-problem I need a hint, how to handle the result of an overlay (difference/ subtract between shapes/complex shapes). As I understand, overlays are meanwhile only stored in a MAP-Model as a (temp.) map-layer. But this layer is only to see within this Map-model!
How can I get this / (copy or so?) it out of this into a different Model or File?
Thx and regards, Ralph
hello
i find a "special way "
create the buffer or overlay in map and save the dgn as a v7 file
map create more than one v7 dgn-files with tempor. names
you find your buffer zone in one off these files
ps: sorry my english is't so good
