When we import ESRI file geodatabase to OpenCities Map, the error is prompted.
Any idea about what file(s) is missing in file geodatabase?
We have tried another dataset which are working properly from other sources.
QGIS is also working properly with both datasets.
We are using OpenCities Map Advanced 10.17.02.48
