HI, I recently installed Open Cities Map Advanced on my computer. Earlier I had Microstation V8.
I need a solution like was Map finishing for Bentley Map V8i. I´ve heard that for Open Cities replacement for map finishing is CAD script. How can I install it or run?
Thank you for your help,
Jasna
There is an entire forum dedicated to OpenCities. You will probably find your answer there.
OpenCities Map Forum
You can move your post with the "More" option just underneath it.
MaryB
Unfortunately those tools have been removed from OpenCities Map. The CADscript (Advanced Map Finishing) tools did not make the transition from V8i to CONNECT
Rod WingSenior Systems Analyst
Is this another product where the ability to produce final deliverables have been overlooked?
Is there any similar solution in OpenCities Map?
There really isn't anything to replace those functions in CONNECT.
Some of the element ordering and WYSIWYG tools you can do with base MicroStation. However, if you used the Table Printing Control you will be hard pressed to try to replicate that functionality using PenTables and DesignScripts. Nothing to create a Map Index, and no more Flexi-Text, plus many other features that are no longer available.
