Use feature attribute to create layer when importing
I have a dataset, NJ Municipalities, (500+ records)
When importing I would like to have the municipalities shape go to a level based on an attribute, either predefined in the DGN or have it create the layer based on the attribute
In the screen shot below I have a township called "Aberdeen", upon imploring i would like it to go to a level based on the GNIS_NAME column, in this case it should go to a level called "Township of Aberdeen"
I came across a similar thread here but trying to implement Inga's solution it was too broad, putting all items matching the criteria to a singe level
It sounded like it was going to be implemented in a Bentley Map upgrade that I read about here but that was 10 years ago
Any thoughts?
OpenCities Advanced
10.17.02.48
Municipal_Boundaries_of_NJ-dbf.csv
