plugin geo_example
Hello, when I export the geoexample from Geospatial, opencitie does not add the previously created plugins to the command manager, how can I fix this?
A thousand thanks
  • Hi Christian,
    I do not know which plugins you were talking about, but to see a new entry in Command Manager List you need to right click in the panel and add/insert a command. Then click the Apply button on the bottom right, save the schema and export the schema. You should see the updated list of Command Manager in OpenCities Map.
    If the problem persists, there may be a problem with the .xml file on your end. From there, I will suggest creating a new schema and adding an entry to Command Manager so you can access it.
    Hope this helps.
    Sebastien
    This is a test
