<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>In Bentley Map V8 XM Select Version is not displaying in Interoperability Interface?</title><link>https://communities.bentley.com/products/geospatial/desktop/f/bentley-map-forum/26168/in-bentley-map-v8-xm-select-version-is-not-displaying-in-interoperability-interface</link><description>Hi,
In Bentley Map V8 XM Select version is not displaying in Interoperability interface.
Do i need to set or configure any thin to retain it back?
Praveen E</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>Re: In Bentley Map V8 XM Select Version is not displaying in Interoperability Interface?</title><link>https://communities.bentley.com/thread/60516?ContentTypeID=1</link><pubDate>Thu, 11 Jun 2009 21:24:49 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:cf1cd21a-22ef-4658-956f-b6a60c7cb7fe</guid><dc:creator>Jeff Bielefeld</dc:creator><description>&lt;p&gt;
Praveen,
&lt;/p&gt;
&lt;p&gt;
You must have the following minimum requirements...
&lt;/p&gt;
&lt;ul&gt;
	&lt;li&gt;Oracle 10.2.0.3 or higher with version enabled tables.&lt;/li&gt;
	&lt;li&gt;Access to a valid ProjectWise&amp;nbsp;Connector for Oracle&amp;nbsp;client license.&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;
...to enable versioning and conflict resolution support in the Bentley Map Interoperability application.
&lt;/p&gt;
&lt;p&gt;
&lt;/p&gt;
&lt;p&gt;
Jeff Bielefeld [Bentley]
&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
