Viewing and modifying Datum Transformation Parameters
Can we add this functionality into MicroStation V8i and BentleyMap V8i. It was there in MicroStation GeoGraphics and also BentleyMap XM. Where has it gone? I understand that assigning Geographic Coordinate Systems has been moved to MicroStation V8i and some of the editing functions are still in Bentley Map V8i but some have disappeared!
Nick.
  • This I like to know, too.
    I'm living in Germany and we have a lot DHDN "local" coordiante systems that has to be shifted with
    7-Parameter Bursa Wolf to be +-0.05m accurate. Shift to ETRF89/ETRS89 projection UTM.
    So where are the datum-editor and ellipsoid-editor gone and when will they return?
    (I was looking in PowerMap V8i)
     Frank
     PS: The deliverd DHDN GCS in V8i are for large scale maps and not accurate enough for +-0.05m accuracy and local land surveying.
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
Reply
     Frank
    Frank
