When will it come?
Frank
Hi Frank. GML support should normally be included in the next release of Bentley Map.
Martin
Could one ask which GML version will be implemented ?
If it is GML 3.1 how much or rather how little will be included ?
Will it be a "Simple Feature Profil" implementation or will it include Arcs and Curves ?
For the SelectSeries 1 of Bentley Map, our interoperability tools will provide support for GML 2.1 and 3.1. It will support the Simple Feature Profile including arc and curves.
Hope this helps.
Keith Raymond
That sounds great, because german national land surveying standard (ALKIS) uses
parts of GML3.1 for a new GIS-Filetype called "NAS", So my hope, building appilications
for that standard will getting a little easier.
Thats great!
We are running PowerMap, but I assume that the GML support will come in the next release of PowerMap too.
I was just to begin to modify our own GML import / export from Tag based attributes to XFM, so this is really good news! Are there somewhere I can see some more informations about the upcoming GML support?
