Nick;
I suspect that you are talking about the print border levels, as defined int ehparameters for the print preparation ? From a basic seed file, these levels are generally not there, untill you run the print preparation tool, and insert the graphics into a drawing. Since the levels were not there, whne inserting the graphics, the levels were created. If yo no longer have graphics ion those levels, you can just remove them from the file using the level manager.
HTH
Jerry
I get the same thing when I use MicroStation V8i.
Please have a look at a post I made in the MicroStation V8i forum;
http://communities.bentley.com/Products/MicroStation/MicroStation_V8i/f/19565/t/15921.aspx
I can't remove the levels.
Nick.
Ahhhhhh, so the issue is that the levels are locked. Ther is a configuration variable that can be set so you can unlock the levels, and thus edit/delete them. If there is someone at your workplace that administrates your Microstation setup, I suspect that they have locked the levels so operators can not create/edit levels at will. I would discuss this with them. If you are that person, then you need to look at the MS_LEVEL_EDIT_ATTRIBUTE_LIST configuration variable.
Hi Jerry,
The configuration variable is Undefined at the moment. What do I need to set the variable to and do I need to set it in both MS V8i and also MSBM V8i?
From the docs
MS_LEVEL_ALLOW_LIBRARY_LEVEL_EDIT "Edit Unused Library Levels" Allows you to edit library levels when it is not yet used in master-file. If not set, then a library level can be edited only when if it is used. If set then a library level that is not yet copied into the master-file can be edited. On editing, the library level will be copied into the master-file.
