Dear
I have got a design file. The design file have multi models, can I create a thematic map from all models, and how to do that?
thanks very much
So you want to only apply the thematic map to the area defined ? Why not limit the reference files when attaching ??
Jerry
Sorry about that. In limiting the reference files, I should explain better. Once those files are attached, by either means, you need to use the clip reference tool in the reference file form. Create the fence for clipping and then once the reference form is open, select all the files, from the list you want to clip.
HTH
thanks Jerry very much.
Can you help me at http://communities.bentley.com/products/microstation/microstation_v8i/microstation_v8i_detailing/f/19566/t/28058.aspx
