Hi all!
After select tool Create Shapes. I select Associate Linkages, but The Associate Linkages tool settings window don't opens. Why? And don't message box.
I cretaed fence, shape and centroid.
I already connect to OLEDB.
Thanks!
...what versions of MicroStation and Bentley Map are you running?
Jeff Bielefeld [Bentley]
Hello Jeff
I'm running version MS v8i and Bently Map V8i.
...so to confirm you are running MicroStation 08.11.05.17 and Bentley Map 08.11.05.49 versions. I just ran a test of those versions and was unable to reproduce the observed behavior (e.g. the tool settings for the "Associate Linkages" command appeared as expected if a fence was present and I had a valid database connection when the command was started). Maybe someone else in this forum can test the same versions and report their findings.
Thank you Jeff.
But I am running V8i, I tried again, but not do. Someone help me.
Can you send me a sample piece of the data along with the database, if it is not too big ???
Thanks !
Jerry
