Map Annotation to microstation text
Hi all,
I'm loving Bentley map (select series 1). Lots of cool stuff. I have a map with 10 different layers, each contains a different shape file with labels. I want to quickly transfer all these labels into microstation text, on different levels that can be open outside of Bentley Map. I have achieved this, to some extent, using the annotation tool. But I have to create a different model for each layer, and reference all the models together and merge them. When merged they all go to the same level.
Am I missing something?
I look forward to creating presentations in map, and not arcmap.
  • ...in the "Map Manager" select multiple map layers (using the control key selection method) that have existing labeling, then right click "Annotation..." and choose the destination model and you should be able to create annotations from multiple layers in a single model.
    Jeff Bielefeld [Bentley]
Reply
