BM Oracle Connection
I am having a problem reading data from my Oracle Database.  I am getting an error "There is no algorithm for assigning the given source geometry to the given target geometry, they do not match."
What does this error mean and how can I work around it?
Cheers Ian
Connection Error
  • Ian;
    If you are usign Oracle Spatial , this looks like you may have a SDO_GEOMETRY type defined in teh table and a feature geometry type that does not match. Please make sure:
    • There is only one geometry type defined for the spatial table.
    • The spatial index is set up and initiated.
    • You have at least 1 key filed defined.
    • You have registered features from the Oracle spatial datasource thru the GSA..
    These should take care of the matching of the geometry types between the Oracle Spatia ltable and the feature types.
    If you are not using Oracle Spatial, just regular realational tables, then please provide more infromation. Version, table definition, feature definition.
    HTH
    Jerry
Reply
  • Ian;
    HTH
    Jerry
  • Thanks Jerry,
    I found the problem.  The data was uploaded from MapInfo Tables (using EasyLoader), and although the geometeries where polylines, some contained multiple polylines (as a geometry collection or multi section line).  This is represented in Oracle as a MULITLINESTRING (as WKT).  These are what was causing the error.
    When I corrected the problem (by simplifing the geometries), and uploaded the data to Oracle, it all worked fine.  I am however having trouble adding and modifing XFM data in a Oracle connection.  I keep getting that the data is locked, and I can't seem to unlock it.  There are no locks on the Oracle server.  We are testing performing data maintenance without setting up the features through the GSA.
    Cheers Ian
