Krister,
The ability to save thematic maps as resymbolized design files does not exist in the current Bentley Map V8i (SELECTseries 1) release but is under consideration for inclusion in a Bentley Map V8i release later this year.
Jeff Bielefeld [Bentley]
Just wanted to affirm that Bentley Map V8i (SELECTseries 3) and above includes the capability to "Export to MicroStation". The command is available on the Map Manager.
* (Post has been edited to correct the Version #)
I don't believe the Export to MicroStation command button is in the (SELECTseries 2) release, you have to upgrade to Bentley Map (SELECTseries 3) to see this option.
Rod WingSenior Systems Analyst
