GSA Topology
I have attached a small movie which shows some topology rules. Please check the link bellow to see what is it about.
Does anyone knows how can this be made? Could someone send me indication of how i can make that?
http://communities.bentley.com//m/narciss_files/default.aspx
If the link doesn't work you can find the movie in my files attachement, please check the extesion to exe.
Narcis
  • Hi Narcis,
    First, I will finally be able to open  your attachement. Thank you!
    Then,  we have an application called Bentley Cadastre which "is an efficient application for creating, maintaining, and analyzing land information." In Bentley Cadastre, you can manage a parcel environment, it mirrors real world workflows for data capture and manipulation, resulting in a rigorous, accurate cadastral fabric. You can manage all your features in topologic model, where all features are relatedby the same topology; where you can modify parcel by "moving one commun point of 2 or more parcels", as you shown in your video.
    Finally, to reproduced you video behavior in Map : " to be able to change the parcels by moving one commun point of 2 or more parcels", you will need to create your own solution by modify/create  a code  (as MVBA file) to give the seame result. For now, is not possible to re-create beahvior from video in Bentley Map except by cusomize your own code or to use Bentley Cadastre.
    Sorry for this insufficient answer.
    Sebastien Lefrancois [Bentley]
    This is a test
  • Hi Narcis,
    I finally find how to do it ... I put some sample files in attach which you can based on to build your project.
    Steps to reproduce:
    1. In GSA, created features and add Placement methods.
    2. Create topology
    3. Associated feature to topology
    4. Update Command Manager
    5. In Command Manager add as keyin Command "ptopo modify"
    6. Create a user workspace
    7. Save, Export and Run.
    8. Now, in Map, you can reproduce the video behavior ...
    HTH,
    Sébastien Lefrançois
    Associate Software Quality Analyst - Geospatial Products
    This is a test
    Myfiles.zip
Reply
  • Hi Narcis,
    Steps to reproduce:
    2. Create topology
    HTH,
    This is a test
    Myfiles.zip
