I am not able to produce expected result from the overlay analysis applied on two XFM feature layers.
Test case: Area feature placed inside another area, both are the same polygon XFM feature, a different area feature placed over these two. If I create overlay topology layer, only "outside area" is included, "inside area" is treated as a hole, so 2 shapes are created, not 3 (see attached picture).
Is it spossible to set overlay tool so inside area will be processed also? Version used is V8i SELECTseries 1.
With regards,
Jan
Just trying to reproduce and understand what you are doing.
Usually if you have 2 of the same ploygon feature types, one instance inside of another, you have a 'hole' or donut situation. I would need to understand why you would want a feautre inside of another of the same feature type ( possibly one is a subset of another ??, not sure).
Thanks !
Jerry
Hi Jerry,
I really appreciate your fast reaction.I will try to explain my idea and what I need a bit more but also will try to be brief :-)
I have a feature "Area", there can be more other areas in a bigger one ... I think you can think about the conditions as about parcels or zones also, all these head towards to "shapes in shape" situation. My original idea was to create simple polygon feature and if there will be smaller area in the bigger one, to create the instance as as a grouped holes cell, where the hole will be filled" by another area. I didn't use collections. It is drawn at the attached picture.
It works quite fine except overlay: The results was created correctly, but for areas in the hole no properties were copied to the resulting shape, which makes it unusable as I need to export properties from all ovelrayed areas. I can send you example project including macro I use to create features with groupe holes cells.
Based on that I returned back to more simple situation and I have tried what the overlay analysis will produce if there will two simple area features placed on top of and I was surprised the inside polygon is treated as the hole. This case I tried with the standard geo_example_designer project, in the attached file is small example.
HTH Jan
Jan,
If the "Area 1" feature instance contains the 2 holes as indicated and "Area 2" and "Area 3" fill those holes the intersection spatial overlay should work as expected. In the sample design file you provided, there does not appear to be a hole in the outer polygon. Attached is a design file which illustrates I think what you are attempting to accomplish. It contains 2 polygon feature classes (e.g. FeatureClass1 and FeatureClass2) with a resulting intersection overlay.
Jeff Bielefeld [Bentley]
Hi Jeff,
you are righ and it is my mistake I mixed a bit two questions / problems in one thread. So short summary:
I offer the following feedback:
