I am not able to produce expected result from the overlay analysis applied on two XFM feature layers.
Test case: Area feature placed inside another area, both are the same polygon XFM feature, a different area feature placed over these two. If I create overlay topology layer, only "outside area" is included, "inside area" is treated as a hole, so 2 shapes are created, not 3 (see attached picture).
Is it spossible to set overlay tool so inside area will be processed also? Version used is V8i SELECTseries 1.
With regards,
Jan
Jeff,
thanks a lot for your explanation of 1st question, it is good to know about this rule and to take it into a consideration. In fact I think such situation is usually the result of not well designed project, but I think it can happen from time to time :-)
Regarding to 2nd issue: Thanks for the confirmation and logging of the problem. As I discovered it during the development and implementation the running project, I am looking forward to the maintenance version you mentioned as this feature is quite valuable and important for us.
