hi,
I am testing Bentley Map on a highway project. We use MS .180, IR .229 and BM .87 (as part of InRoads 'extension'). I imported SHP (+ SHX and DBF) file into BM and I can see, display and make simple operation (symbology, labeling...) on dataset. However overlay and buffer are disable. May I ask for a help with this - any particular reason these toolas are off?
Piotr
If you go back to the original work file ( I noticed that the drop down menu has the 'Stop Editing ...' on it ), and then try to do your buffers and overlays, does it work ?
HTH
JErry
Jerry,
No, it does not. For both 'Make Active for Editing' and 'Stop Editing' buffer and overlay are disable. We tested this on MS + BM and it works but when we start BM with InRoads running - does not.
Yep, From your desciption on the original posting, I did do this thru the Inroads install (
) and the buffer and overlay was available.
Can you repeat the above with a new drawing and let me know ???
If that works for you, can you send me the drawing that you have done the shape file import into (via email if it is not too large , ie > 2mb) so I can look at it ??
Thanks !
Jerry.
On both: '...current DGN file' and '...new DGN file' tools do not work.
May I ask for your email adress, please - I will send you DGN, SHP, SHX and DBF files?
Piotr,
Are you in a 3D design file? If so the "Buffer..." and "Overlay..." tools will be disabled.
Jeff Bielefeld [Bentley]
