Only a few tables are visible through Oracle import
Hi, I try to import data from Oracle Spatial but only a few of my tables turns up. The all have one geometry column, one geometry type, spatial indexes with a specified geometry type. It seems that only the tables with a simple primary key (one column) are visable. Is that the case or could it be anything else that filters out some tables? Regards, Krister Surell
