FeatureMgr in VB.NET
I connect the application using the following code.
        Dim m_App As MicroStationDGN.ApplicationObjectConnector = GetObject(, "MicroStationDGN.ApplicationObjectConnector") '
        Dim msDGNApp As MicroStationDGN.Application = m_App.Application
        Dim m_DF As MicroStationDGN.DesignFile = msDGNApp.ActiveDesignFile
This is how I get the DesignFile.
From here how will I get the FeatureMgr Class initialized.
Or Is there any othere method. Please help
Liju Mathew Varghese
  • This is what I'm doing in Vb.NET
    Public Class Form1
       Dim MSApp As Application
       Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
           Dim app As MicroStationDGN.ApplicationObjectConnector
           Try
               app = GetObject(, "MicroStationDGN.ApplicationObjectConnector")
               MSApp = app.Application
               MsgBox("Connected")
           Catch ex As Exception
               MsgBox("Open Power Map" & vbCrLf & ex.Message)
           End Try
       End Sub
       Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
           Dim el As Element
           With MSApp.ActiveModelReference
               el = .GetElementByID64(txt.Text)
               If el IsNot Nothing Then
                   Dim Mgr As New XFT.FeatureMgr         ' Error Happens here
                   Dim ft As feature
                   ft = Mgr.CreateFeature(el)
               Else
                   MsgBox("Element Not Found")
               End If
           End With
       End Sub
    End Class
  • ...you will need to use the CreateObjectInMicroStation method on the MicroStation application object to ensure that your XFT objects are created in the MicroStation's address space. The CreateObjectInMicroStation method is useful for an out-of-proc program that needs to create objects from a COM server that must run in MicroStation's address space.
    Following is a simple VB.NET code example which uses CreateObjectInMicroStation to create XFT objects as previously described.
    Imports DGN = Bentley.Interop.MicroStationDGN
    Imports XFT = Bentley.Interop.Xft
    Public Class Form1
        Friend m_xftCmdMgr As XFT.CmdMgr
        Friend m_xftFeatureMgr As XFT.FeatureMgr
        Friend m_xftFeatureEnumerator As XFT.FeatureEnumerator
        Friend m_xftDialogMgr As XFT.DialogMgr
        Friend m_xftPropMgr As XFT.PropMgr
        Friend m_MSApp As DGN.Application
        Friend m_ActiveFile As DGN.DesignFile
        Friend m_CurrentModel As DGN.ModelReference
            test()
        End Sub
        Friend Sub xft_initialize(ByVal msapp As DGN.Application)
            m_MSApp = msapp
            m_xftFeatureMgr = CType(m_MSApp.CreateObjectInMicroStation("xft.FeatureMgr"), XFT.FeatureMgr)
            m_xftFeatureEnumerator = CType(m_MSApp.CreateObjectInMicroStation("xft.FeatureEnumerator"), XFT.FeatureEnumerator)
            m_xftCmdMgr = CType(m_MSApp.CreateObjectInMicroStation("xft.CmdMgr"), XFT.CmdMgr)
            m_xftPropMgr = CType(m_MSApp.CreateObjectInMicroStation("xft.PropMgr"), XFT.PropMgr)
            m_xftDialogMgr = CType(m_MSApp.CreateObjectInMicroStation("xft.DialogMgr"), XFT.DialogMgr)
        End Sub
        Sub test()
            Dim oMSApp As Bentley.Interop.MicroStationDGN.Application
            Dim oMSAppConnector As Bentley.Interop.MicroStationDGN.ApplicationObjectConnector
            ' Create our MicroStation application object.
            oMSAppConnector = GetObject(, "MicroStationDGN.ApplicationObjectConnector")
            oMSApp = oMSAppConnector.Application
            ' Initialize our global XFT objects in the MicroStation process.
            xft_initialize(oMSApp)
            ' Display the currently active design file.
            MsgBox(oMSApp.ActiveDesignFile.Name)
            ' Create an XFT feature enumerator.
            m_xftFeatureEnumerator = m_xftFeatureMgr.GetFeaturesInDgnList(oMSApp.ActiveDesignFile)
            Dim oFeature As XFT.feature
            Dim sPropertyList As String
            Dim oProperty As XFT.Property
            ' Loop through our feature enumerator and create string that contains the property names and values.
            Do While m_xftFeatureEnumerator.MoveNext
                oFeature = m_xftFeatureEnumerator.Current
                Dim oProperties As XFT.PropertyEnumerator = oFeature.GetPropertyEnumerator
                sPropertyList = "Property Values: "
                Do While oProperties.MoveNext
                    oProperty = oProperties.Current
                    sPropertyList += " " + oProperty.Name + " = " + oProperty.value
                Loop
                ' Display the property names and values.
                MessageBox.Show(sPropertyList)
            Loop
        End Sub
    End Class
    Jeff Bielefeld [Bentley]
  • Thanks Jeff. This helped me a to put my step ahead.
Reply Children
