I'm running Bentley Map V8i SS1 through InRoads. I have my workspace set up so that when I launch InRoads from the Windows Start menu Bentley Map is started as well. In this configuration the Command Manager displays automatically which is very nice.
My problem is when I close it how do I get it to redisplay without exiting MicroStation completely and restarting?
Thanks.
I have standalone Bentley Map without InRoads, so I am not sure if there are no some differences, but you can open/close the Command Manager dialog with keyin "activate readonlymethod MainMenu2|Open".
HTH Jan
That works. Thanks Jan
Rod WingSenior Systems Analyst
