Unable to setup OSTN'02
I'm having problems setting up this coordinate system.
I'm setting up a brand new installation (new PC) and have installed the following versions of BM V8i and MS V8i.  I have followed the previous method to setup OSTN'02 in Bentley Map as per the forum post below;
http://communities.bentley.com/products/microstation/microstation_v8i/f/19565/p/25312/61207.aspx#61207
When I attempt to generate a lat and long grid using the grids and graticules dialog, I get the following error;
Linear / angular unit mixup.
Bentley Map then crashes.
I've attached the exception log generated and also the dgn I'm using.
Nick.
Bentley Map V8i SS1 Ver. 08.11.07.87
MicroStation V8i SS1 Ver. 08.11.07.171
Windows 7 x64
C8028-Grid-GG (2).dgn
Parents Reply Children
