I have a project where feature areas have a start/end date. Trying to add a filter for the Start Date say > 1/12/2011 show no entries.
Similarly, trying to setup thematic maps based on a date only work for the = operator. For instance, determining which areas are under construction at a specific date. Where StartDate <= 1/1/2012 and Where EndDate >= 1/1/2012 do not change any symbology. Checking for StartDate = 04/16/2011 does show the symbology correctly for that Work Area. Is there something I'm missing? Thanks.
Bentley Map V8i (SELECTseries 1) 08.11.07.87
The data browser now filters the dates correctly:
However, I seem to have a similar problem on the themes.
Would appreciate any more suggestions.
Bryan
