is that possible
If so where to change settings for that
TIA
Erik Wirring
Erik,
To change the default “Analyze Result” behavior so that all of the business properties from root and sub-feature instances are shown, open the “...\Bentley\Map\xml\methods\methods.xml” configuration metadata file using “Notepad” and locate the “rootXmlOnly” string and replace with “allXml” then save and close the file. Close and restart your Bentley Map session.
Jeff Bielefeld [Bentley]
