Interoperablity: Import Search and Where Clause
Is there an easy way to populate the Where Clause field in the Interoperability window from the SQL statement built using the Search Tool?
The only way I've found to do this is manually key in the Where Clause after I get the proper search result.
Thanks.
Parents Reply Children
