XFT.ILocateOpEvents
Where are we using this interface and can i have an example of how to use in VBA or VB.NET
  • ...in VBA you can use the XFT.ILocateOpEvents interface as follows. First declare a new XFT locate operation object and set desired criteria.
    Private Sub CommandButton1_Click()
        Dim oLocateOp As New xft.locateOP
        oLocateOp.IncludeOnlyFeatures = True
        oLocateOp.IncludeFeatureName "BuildingText"
        oLocateOp.ExcludeFeatureName "Building"
        CmdMgr.StartLocateOperation oLocateOp, New clsLocateFeatureOp
    End Sub
    Next, create a new class module which implements the ILocateOpEvents interface as follows:
    Implements ILocateOpEvents
    Private Sub ILocateOpEvents_OnCleanup()
    End Sub
    Private Sub ILocateOpEvents_OnFinished(ByVal oLocateOp As xft.ILocateOp)
        Dim fe As FeatureEnumerator
        Set fe = oLocateOp.GetLocatedFeatures
        fe.MoveNext
        Dim oFeature As xft.feature
        Set oFeature = fe.Current
        MsgBox "Located Root Feature Class = " + oFeature.Name
        Dim ee As ElementEnumerator
        Set ee = oLocateOp.GetLocatedElements
        ee.MoveNext
        Dim oElement As element
        Set oElement = ee.Current
        Dim oSubFeature As xft.feature
        Set oSubFeature = oFeature.GetSubFeatureOrSelfByID(oElement.ID)
        MsgBox "Located Sub-Feature Class = " + oSubFeature.Name
    End Sub
    Private Sub ILocateOpEvents_OnRejected(ByVal RejectedReasonType As xft.LocateOpRejectedReasonType, RejectedReason As String)
    End Sub
    Private Sub ILocateOpEvents_OnTerminate()
    End Sub
    Private Sub ILocateOpEvents_OnValidate(ByVal RootFeature As xft.IFeature, ByVal element As element, Point As Point3d, ByVal View As View, Accepted As Boolean, RejectReason As String)
    End Sub
    Jeff Bielefeld [Bentley]
Reply
    End Sub
    End Sub
        fe.MoveNext
        ee.MoveNext
    End Sub
    End Sub
    End Sub
    End Sub
