I am trying to save/write the results of a thematic symbolisation to DGN file, but cannot find in the help files or elsewhere how to do this. Can anyone assist? (Map SS1 08.11.07.113)
Unfortunately, it’s not possible to do it. The workaround is to “Save As” your symbolization and make sure you have created a map model in your active file, you will then be able to load the saved symbolization as a .theme file.
Sebastien Cote
However, notice that it will not work with the Buffer \ Overlay.
