3D XFM
Is there a fast way to create a solids XFM 3D. I have a file where there are hundreds of solids. I would like to create a 3D project XFM, without clicking on each individual (drop and create) vba or mdl? I prefer vba :)
regards
adrian
  • Hi. This seems like a good idea. The way I normally do it manually for testing purposes is to use the Microstation "drop" command to drop the solid into a set of faces. I then select those faces and use the feature class's promote method to make an XFM feature out of the set of faces.
    I suggest that you look into the Microstation drop command and see what apis are available to do this. I think you could write a program that processes your solids one at a time: dropping it, creating a selectionSet out of the faces of one solid and launching the promote command by sending a keyin such as "activate method FEATURENAME|Promote". If this keyin prompts for user input you could probably give it the inputs using other keyins.
    Note that this has not been tried, these are just suggestions.
       Martin
  • Hi Martin,
    I think it might be a good direction to create applications.
    Permit me, that I will take advantage of your suggestions :)
    regards
    adrian
