SetProperty methode on Feature object will not update property to empty or blank String
Hi
I have a funny problem. When I try in a VBA program  to update a Property to a blank or empty line PowerMap keeps the old value. If I use any other string the property is set to the new value.
All my Properties are strings. There is no XFM schema so PowerMap works with sessionbased featuredefinition.
I have no troubles to do the same when I use the "Edit XFM Feature" tool or the Databrowser..
Typical I do something like this:
    For i = 1 To UBound(Attributs)
        oFeature.setProperty Attributs(i).Felt, Attributs(i).Data
   Next i
   oFeature.Write False
Any good ideas how I get the blank string into the property ???
Erik Wirring
Parents Reply Children
