Interoperability Key-In
Hi All,
I am working with Bentely Water (Bentley Map with a bit extra) and I need to create a menu option (or button) to both launch the Interoperability dialog for import SHP and TAB files, but I also need to have a button that will open an Oracle Spatial connection (where all our GISDATA lives).
Is this able to be done as a Key-In or do I need to right a VBA script for this??
Cheers Ian
