Problem with using LocateOp with in A feature numerator from a previous LocateOp
Hi
I have a problem with making a locate while running through a feature enumerator from a previos made scan, PowerMap crashes when going to the second item in the outer loop.
I have made this very simple application to show the problem (The application ans a test designfile is attached in a zip)
********* Main appication ***************
Attribute VB_Name = "modLocateTest"
Public ScanFeatureEnumerator As xft.FeatureEnumerator
Public ScanFeatureCount As Long
Public XpathFeatureEnumerator As xft.FeatureEnumerator
Public XpathFeatureCount As Long
Public Function GetFeaturesByXpathAndPoint(ByVal Xpath As String, Pkt As Point3d, ByVal SnapDist As Double) As Integer
' Function makes a XpathScan near Point Pkt
' Found features are in enumaerat XpathFeatureEnumerator
' Function returns number of found features
Dim oLocateOp As New xft.locateOp
Dim oPoint As New xft.InputPoint
Dim toleranceValue As New InputValue
toleranceValue.SetTypeAndValue ValueType_VALUE, Str(SnapDist)
oLocateOp.Tolerance = toleranceValue
oPoint.SetLocation Pkt.X, Pkt.Y, Pkt.Z, False
oLocateOp.ScanAtPoint = True
oLocateOp.ReferencePoint = oPoint
oLocateOp.Mode = LocateOpMode.locateOpModeScan
oLocateOp.Xpath = Xpath
oLocateOp.AutoAcceptScanFile = True
CmdMgr.StartLocateOperation oLocateOp, New clsLocateXpath
GetFeaturesByNameAndPoint = XpathFeatureCount
End Function
Public Function ScanFeaturesByName(ByVal FeatureNames As String) As Integer
' Function makes a Scan for the comma delimited featurenames
' Founf features are in enumarator ScanFeatureEnumerator
Dim Features() As String
Dim i As Integer
If Trim(FeatureNames) <> "" Then
    Features() = Split(FeatureNames, ",")
    For i = 0 To UBound(Features)
        oLocateOp.IncludeFeatureName Features(i)
    Next
End If
CmdMgr.StartLocateOperation oLocateOp, New clsScanLocate
ScanFeaturesByName = ScanFeatureCount
End Function
Public Sub main()
Dim oFeature As xft.feature
Dim Pkt As point3d
If ScanFeaturesByName("Brønd,TilslutningKn,FiktivKnude,DelLednKnude,AndenKnude") > 0 Then
    Do While ScanFeatureEnumerator.MoveNext
        Set oFeature = ScanFeatureEnumerator.Current
        'MsgBox oFeature.GetXml
        Pkt.X = oFeature.Geometry.AsCellElement.Origin.X
        Pkt.Y = oFeature.Geometry.AsCellElement.Origin.Y
        Pkt.Z = oFeature.Geometry.AsCellElement.Origin.Z
        If GetFeaturesByXpathAndPoint("Dæksel", Pkt, 5#) > 0 Then
            Do While XpathFeatureEnumerator.MoveNext
                Set oFeature = XpathFeatureEnumerator.Current
            Loop
        End If
    Loop
End If
End Sub
************** Two LocateOp clasees *****************
VERSION 1.0 CLASS
BEGIN
  MultiUse = -1  'True
END
Attribute VB_Name = "clsScanLocate"
Attribute VB_GlobalNameSpace = False
Attribute VB_Creatable = False
Attribute VB_PredeclaredId = False
Attribute VB_Exposed = False
Implements ILocateOpEvents
Private Sub ILocateOpEvents_OnCleanup()
End Sub
Private Sub ILocateOpEvents_OnFinished(ByVal locateOp As xft.ILocateOp)
modLocateTest.ScanFeatureCount = locateOp.LocatedFeaturesCount
Set modLocateTest.ScanFeatureEnumerator = locateOp.GetLocatedFeatures
End Sub
Private Sub ILocateOpEvents_OnRejected(ByVal RejectedReasonType As xft.LocateOpRejectedReasonType, RejectedReason As String)
End Sub
Private Sub ILocateOpEvents_OnTerminate()
End Sub
Private Sub ILocateOpEvents_OnValidate(ByVal RootFeature As xft.IFeature, ByVal element As element, Point As Point3d, ByVal View As View, Accepted As Boolean, RejectReason As String)
Accepted = True
End Sub
VERSION 1.0 CLASS
BEGIN
  MultiUse = -1  'True
END
Attribute VB_Name = "clsLocateXpath"
End Sub
modLocateTest.XpathFeatureCount = locateOp.LocatedFeaturesCount
Set modLocateTest.XpathFeatureEnumerator = locateOp.GetLocatedFeatures
End Sub
End Sub
End Sub
Accepted = True
End Sub
Thanks in advance
Erik Wirring
LocateTest.zip
  • Hi. It is currently not supported to use the result of a locate operation directly within another locate operation (nesting). Even though you are storing the pointers to the iterators separately, internally this doesn't work. The construction of the second locate operator destroys the list owned by the first.
    For now I suggest that you first iterate on the results of your first iterator and store the list of result features in your application, and as a second step work with that local list for your second locate operation.
    Hope this helps,
       Martin
  • Hi Martin
    Thanks for the help. I have change the routines so they saves the found features in features arrays instead. It works fine, I was some unsure whether I would be able to update the features, but that seems to work too.
    Erik
