selection set from database properties
In GeoGraphics there was a way to get a selection set based upon a SQL query.  .In GeoGraphics the Visual SQL Query Builder had a menu item called "Dataset."  The menu dropdown allowed several selections including one to "Add to selection set."
Is there anything similar in Bentely Map?  The Visual SQL Query Builder does not have the "Dataset" item as a selection.
