set subfeature text to Align
I have a feature in code (a water main).  It has a SUBTEXT defined in the MA called W_MainText.  (Interactive placement via the +A icon works fine.)
So I write the text after getting the right point for placement.  The first 3 lines below work fine.  But you can see from the lines below that that I'm groping.  A quick 30 minutes with the vba.chm and the xft.chm have made this process a bit clearer, but I can't seem to close on setting the placement mode to ALIGN.
            CreateAnnotation "W_MainText", oFtr, pntForAnno
            oFtr.ApplyAttributeChanges
            oFtr.Write False
            ' need to get at the subfeature somehow...
            Dim subFeature As feature
            Dim j As Long
            Dim subCount As Long
            subCount = oFtr.SubFeatureCount
            For j = 0 To subCount - 1
                Set subFeature = oFtr.GetSubFeature(j)
                Set the text placement mode to ALIGN
            Next j
I suppose I should have set the placement mode before CreateAnnotation "W_MainText", oFtr, pntForAnno, right?
  • So a bit more chm reading and it looks like I could
               Dim oTextParams As New xft.TextParams
               oTextParams.TextMode = annotationTextMode_<I wish for "Align" here>
    Except there is no annotationTextMode_Align
  • I thought surely this would work, but all the text comes out at zero, even though I can see that oAngle is set to other values.
               Dim oAngle As New xft.InputValue
               oAngle.SetTypeAndValue ValueType_VALUE, dblAngle    <I know dblAngle is correct.>
               Dim oRotation As New xft.Rotation
               oRotation.SetByAngle oAngle
               oTextParams.SetAlignment oRotation
               oFtr.Write False
  • Charlie,
    I would recommend that you review the PlaceAnnotation2 method in the Library module of the xfmStdOpsLib.mvba (e.g. the XFM Standard Operations Library) delivered with Bentley Map in the ...\Bentley\Map\vba folder. The code in that method will demonstrate the various text placement modes such as "Away", "Align", "On" and others. If you've further questions after reviewing that code, please let us know.
    Jeff Bielefeld [Bentley]
  • Success!  Although I did not have much luck with PlaceAnnotation2 (It seemed aimed at interactive placement, and I could never quite get the subfeature to rotate), I adapted a function provided by Bentley services.  The main deal was to set the rotation on the initial text node placement rather than let it place at Matrix3dIdentity and then try to edit the subfeature.
    Public Function CreateAnnotationWithRotation2(annoname As String, ByRef oFtr As xft.feature, _
                                                   pntCreate As Point3d, rotation As Matrix3d)
    'to add anno
    Dim oNewElem As Element
    Dim oNewFtr As xft.feature
    'create a text node elem
    Set oNewElem = Application.CreateTextNodeElement1(Nothing, pntCreate, rotation)
    Set oNewFtr = New xft.feature
    'add this as a feature to the parent
    'these set the various values required for creating a feature
    oNewFtr.Geometry = oNewElem
    'alias must equal the Placement name; i.e. "OH Primary" to get children
    oNewFtr.Alias = annoname  '"W_FireHydrant_Text1"
    'name must equal the stored name; i.e. "edist_oh_primary"
    oNewFtr.Name = annoname
    'ftrTable
    oNewFtr.Group = "xPlacement"
    'FtrName = "Pole"
    'end value set
    'add the child records to the parent
    oNewFtr.SetParentFeature oFtr
    oNewFtr.AddSelfToParent
    xft.PropMgr.InitializeOperationProperties oNewFtr.Name, "W_MainText"
    oNewFtr.InitializeProperties "W_MainText"
    End Function
    Before calling this function, you have to determine the rotation, which is done by finding the angle from end points of the closest segment.  This sub also offsets the text a bit away fromt he line, and corrects that offset for lines that slant between 290 and 340 degrees.
    Private Sub PlaceAnno(pntOnMain As Point3d, oFtr As feature, oElem As Element)
        Dim pntForAnno As Point3d
        Dim rotationMatrix As Matrix3d
        Dim oTempLineElement As LineElement
        ' point for anno will be left in X and up in Y...
          pntForAnno.X = pntOnMain.X - 60
          pntForAnno.Y = pntOnMain.Y + 60
          pntForAnno.Z = pntOnMain.Z
          ' find the segment for deriving the text rotation...
          Dim index As Long
          Dim pntForRotation1 As Point3d
          Dim pntForRotation2 As Point3d
          Dim dblAngle As Double
          Dim dblAngleInDegrees As Double
          Set oTempLineElement = oElem.AsLineElement
          index = oElem.AsVertexList.GetClosestSegment(pntOnMain)
          pntForRotation1 = oTempLineElement.Vertex(index + 1)
          pntForRotation2 = oTempLineElement.Vertex(index + 2)
          dblAngle = GetAngleFromEndPts(pntForRotation1, pntForRotation2)
          dblAngle = dblAngle - Pi / 2
          If dblAngle > Pi / 2 And dblAngle < 3 * Pi / 2 Then
              dblAngle = dblAngle + Pi
          End If
          ' correct for a pipe that runs northwest to southeast, i.e., slope = -1
          ' which means the dblAngle is in the 315 range (360 minus 45)...
          dblAngleInDegrees = Application.Degrees(dblAngle)
          If dblAngleInDegrees < 0 Then
            dblAngleInDegrees = dblAngleInDegrees + 360
          End If
          If dblAngleInDegrees > 290 And dblAngleInDegrees < 340 Then
            pntForAnno.X = pntOnMain.X + 60
          End If
          rotationMatrix = Matrix3dIdentity
          rotationMatrix = Matrix3dFromAxisAndRotationAngle(2, dblAngle)
          CreateAnnotationWithRotation2 "W_MainText", oFtr, pntForAnno, rotationMatrix
          oFtr.Write False
    End Sub
    This sub is called by an earlier sub that arranges multiple placements of text if the pipe is long:
    Private Sub CreateAnnoForLineElementTypes_Multiplacement(ByRef oFtr As feature, oElem As Element)
        ' Like the others, but this version wants to place the anno evey 1,000 feet or so...
        Dim lengthTotal As Double
        Dim lengthRemaining As Double
        Dim lengthCumulative As Double
        Dim pntOnMain As Point3d
        lengthTotal = oFtr.GetProperty("ACTUAL_LENGTH")
        lengthRemaining = lengthTotal
        lengthCumulative = 0
        ' omit annotation for short pipes (less than 300 feet actual length)...
        If lengthTotal > 300 And lengthTotal <= 1000 Then
            ' set the point for placing the text...
            pntOnMain = oElem.AsTraversableElement.PointAtDistance(lengthTotal / 2)
            PlaceAnno pntOnMain, oFtr, oElem
        Else
            ' length >= 1000
            ' so place anno at 700 and see if there is another 1000...
            Do While lengthRemaining > 1000
                pntOnMain = oElem.AsTraversableElement.PointAtDistance(lengthCumulative + 700)
                lengthRemaining = lengthRemaining - 1000
                lengthCumulative = lengthCumulative + 1000
            Loop
        End If
    End Sub
    And it all starts with a button click that sets up a scanner enumerator that picks just mains and then selects the processing style based on element type.
    Private Sub cmd_Create_Main_Annotation_Click()
        Dim ee As ElementEnumerator
        Dim oElem As Element
        Dim oScanCriteria As ElementScanCriteria
        Dim oLevel As Level
        Dim oLevels As Levels
        Dim oFtr As xft.feature
        Dim i As Integer
        Dim elemType As String
        Dim elemCounter As Double
        elemCounter = 0
        Dim iCounter As Long
        iCounter = 0
        ' tell the user you're working...
        lblStatus.Caption = "Working..."
        DoEvents
        ' restrict scan criteria to Mains...
        Set oLevels = ActiveDesignFile.Levels
        Set oScanCriteria = New ElementScanCriteria
        oScanCriteria.ExcludeAllLevels
        For i = 1 To oLevels.count
            Set oLevel = oLevels.Item(i)
            If UCase(oLevel.Name) = "W_MAIN" Then
                oScanCriteria.IncludeLevel oLevel
            End If
        Next i
        ' scan for mains...
        Set ee = ActiveModelReference.Scan(oScanCriteria)
        Do While ee.MoveNext
            elemCounter = elemCounter + 1
            Set oElem = ee.Current
            Set oFtr = CreateFeature(oElem)     ' oFtr will be the W_MAIN...
            elemType = oElem.Type
            Select Case elemType
                Case "3"    ' line...
    '                CreateAnnoForLineElementTypes oFtr, oElem
                    CreateAnnoForLineElementTypes_Multiplacement oFtr, oElem
                Case "4"    ' linestring...
                Case "12"   ' complex string...
                    CreateAnnoForComplexStringElementTypes oFtr, oElem
                Case "16"   ' arc...Let's ignore these for now...
                Case Else   ' one complex shape in data set. Ignore...
            End Select
    '        If elemCounter > 200 Then
    '            Exit Do
    '        End If
        Loop
        Debug.Print elemCounter
        Debug.Print iCounter
        ' tell the user you're done...
        lblStatus.Caption = "Writing annotation for mains is complete."
    End Sub
    This code processes about 20,000 mains in about 40 seconds.
Reply
    'to add anno
    'ftrTable
    'FtrName = "Pole"
    'end value set
    End Function
          Dim index As Long
          End If
          End If
          End If
          oFtr.Write False
    End Sub
        Else
            ' length >= 1000
            Loop
        End If
    End Sub
        Dim oLevel As Level
        Dim i As Integer
        elemCounter = 0
        iCounter = 0
        DoEvents
            End If
        Next i
        ' scan for mains...
                Case "3"    ' line...
            End Select
    '            Exit Do
    '        End If
        Loop
    End Sub
