Gdi import from oracle spatial ommits compound polygons geometry (gtype=1003,elem_info=1005)
Hi all,
I encountered a problem while trying to import Oracle Spatial's compound polygons (that are those which contains both straight and arc segments - sdo_gtype=2003, elem_type=1005). I am using VBA to connect and import via gdi keyins:
myMSApp.CadInputQueue.SendKeyin "gdi open name=iskn user=" & ISKN_USER & " password=" & ISKN_PASSWD & " server=" & ISKN_SID
myMSApp.CadInputQueue.SendKeyin "gdi import storage=iskn feature=jino_hranice_kp_pol level=""Hranice z RN_POLYGONY_KU"" color=4 weight=0 style=0"
Specified table (jino_hranice_kp_pol) contains polygons - with or without hole(s) (gtype=2003,elem_type=1003), multipolygons - with or without hole(s) (gtype=2007, elem_type=1003) and the discussed compound polygons (gtype=2003,elem_type=1005).
Import is successfull, but all of the compound geometries are omited without providing any error message.
All geometries in the table are valid (based on the sdo_geom.validate_geometry_with_context), table is registered in user_sdo_geom_metadata, has spatial index, primary key, everything...
MDSYS.SDO_GEOMETRY(2003, NULL, NULL, MDSYS.SDO_ELEM_INFO_ARRAY(1,1005,3,1,2,1,203,2,2,207,2,1), MDSYS.SDO_ORDINATE_ARRAY(-741245.35,-1043118.49,-741238.33,-1043100.16, ............))
I am using Oracle 11g (version 11.1.0.7.0).
Any clue, what am I doing wrong or any other idea how to achieve importing compound polygons from VBA?
Thank you for any kind of help,
Jiri Novak,
CUZK
  • Could this be because you have more than one sdo_gtype defined in the table ?
  • I don´t think so - I prepared a test table, where there were geometries of just one sdo_gtype = 2003 and with the spatial index with parameter 'layer_gtype=polygon' defined and it did not solve the problem. Still the compound polygons continues to be skipped :(
  • ...select the Bentley.Geospatial.Extensions.Oracle.tlb type library when setting your reference.
    Jeff Bielefeld [Bentley]
  • Great, it was really a Visual Studio version issue, compiling with VS 2005 succeded without any error. I managed to set the reference into VBA Microstation's macro and I wrote a simple test sub:
    Sub Test()
       Dim oOracleInstance As New OracleSpatialExtensions
       oOracleInstance.connectAdhoc "publ", "publ", "publ"
       'oOracleInstance.queryClass "PUBL_JINO_HRANICE_KP_OBVODOVE", "KP_KOD=101"
    End Sub
    I am connected without any problem, but querrying a table do nothing, I was inspecting the code in c# and "query all" should be by default.
    Therefore the only problem could be in feature class. I do have in oracle table called "jino_hranice_kp_obvodove" in schema "publ" which has a collumn called "kp_kod", what then have I wrong in the function call?
    Thank you very much for your help,
    Jiri
  • When I tried to work in a schema previously defined in BGA everything worked. So i have to have something badly in the class name while using ad hoc connection... I have no idea what :(
    I can do it that way (prepare a XFM scheme for tables to be imported in advance), but the problem is that I am executing microstation from VB Script (command line) via COM interface (I am exporting data to approx 110 design files) and I don't know how to tell it the newly created instance should use user asociated to XFM scheme...
    I am using something like:
    Set myMSAppCon = CreateObject("MicroStationDGN.ApplicationObjectConnector")
    Set myMSApp = myMSAppCon.Application
    myMSApp.Visible = True
    Set DesignFile = myMSApp.OpenDesignFile(vectorizedFileV8, False)
    Is there any way how to achieve it?
    Thank you very much,
    Jiri
  • ...you could try to set the _USTN_USERNAME environment variable to the name of the user workspace (e.g. SET _USTN_USERNAME=geo_example_designer) in the shell before starting your session.
  • Jiri,
    For you adhoc connection (e.g. without a schema) code, you will need to add the following highlighted lines to the connectAdhoc method:
                    public void connectAdhoc(string userName, string password, string serviceName)
                        GDI.GDIExplorerOracleImportsNode oracleNode = GDI.GDIExplorerAddIn.Instance.OracleNode;
                        if (oracleNode != null && oracleNode.CountSubNodes() == 0)
                            ECSTORAGE.IECStorage storage = GDI.GeoDataInterchangeAddIn.Instance.OpenOracleStorage(userName, userName, password, serviceName, false);
                            if (storage != null)
                                GDI.GDIExplorerOracleNode node = new GDI.GDIExplorerOracleNode("Current Session");
                                node.AddStorage(userName + "@" + serviceName, storage, false, null);
                                oracleNode.AddSubNode(node);
                                if (GDI.GeoDataInterchangeAddIn.Instance.MasterFileImport == null)
                                    GDI.GeoDataInterchangeAddIn.Instance.MasterFileImport = node;
Reply
  • Jiri,
