Hi, I have a set of dgn + access database that I can't export properly to shp using Bentley Map. I think the problem is data related because I have several other projects that can be exported ok. The problem is that the shp file contains no attributes after it is exported. The geometry is ok but the .dbf is empthy exept for a Geometry_A and Geometry_P column that are not originating from my database. The elements look ok in Bentley Map can be revived, annotated, used in Map_Manager symbology and I can use the sql review command. If I use Preview in in the export dialog I see none of my attributes there only Geometry_A and Geometry_P.
I am using Bentley Map version 08.11.07.113
I wold be gratefull if anybody avare of anything that might explain this could give me a hint.
regards
karl
Karl,
It sounds as if the Dynamic Feature Scoring (DFS) may be finding at least one feature occurence in your design file which has no RDBMS linkages before all of the other occurances with the linkages. When this happens, the inferred feature class definition will not have any business properties. Attempts to use the "Data Browser" or "Interoperability > Preview" functions which result in no apparent business properties are usually a good indication that the inferred feature class is using a simple MicroStation element with no RDBMS linkages etc...
Do you possibly have any elements w/o RDBMS linkages that are on the same level as those which have your valid RDBMS linkages? In the "Utilities" tool palette of Bentley Map, the "Masking" tool has display modes which can help you visualize elements with and w/o RDBMS linkages. After removing (or moving to another level) those elements which have no RDBMS linkages and restarting a new Bentley Map session, your data should show business properties and export as expected.
Jeff Bielefeld [Bentley]
Hi Jeff, this might be the problem. If I create a new level and move some of my polygons to it then I can export that level ok. The Masking tool show me no "no database" elements but I can see there are more elements on my problem level than the number of vsql review responds. The DBCHECK command tells me all is ok. What would be helpfull in this case would be the possibility to select and move to another level the vsql review results. That possibility used to be in the vsql dialog (and hilight) but it's looks like it's bin removed in BM or do you know of a way to do this ?
You should be able to use the "Change Attributes" command along with a "Fence Filter" to move your elements to a new level. For example...
I have this problem experienced before, you need to re-evaluate your data if your data has no error, meaning using Data Browser review your attributes using fence or view. If your data have errors you cannot export your data into shp file. Correcting the errors is your passport to export your data correctly.
Hope this helps,
Jun
Thanks Jeff, this works. If I do this I can see that there are 2 elements on my polygon-layer that are excluded by the filter and then I can export the new level ok.
In this case I am working in a file with only one level but I regularly have to assist customers that are having shp-export problems that are working with 20-30 levels in one file and if the export process fails there is no indication (well there is the element id but it's tricky to track down) of what elements are failing. I have experienced that Bentley Map is strict on that my data is clean and if I for instant have lines or text on a point level the export process stops.
Is it not possible in future versions to have the option of just skipping over problems like these and complete the export ?
