Feature Items in Operation(Property Watcher) is not ocurring
Hi all
I was trying to create Property watcher to my Combo box property using the CurrentListLookup as Type but when I double click the dropdown arrow under the operation, I notice that the list of the features is missing. Did I missed something with my workflow? How can I view the list?
 08.11.07.87
Jun
  • Did you double click in he field to activate the drop down list ???
  • Hi Jun,
    It has an issue with update of dropdown list of operation feature in Property Watcher tab. It has been reported to internal team assigned to that product. Please refer to TR 306724 as number of internal report for this issue.
    I suggest you the following workaround:
    1. Save the project.
    2. Close GSA
    3. Re-launch GSA
    4. Open saved project
    5. Go back to dropdown list of operation feature in Watcher Property tab.
    6. List is now updated.
    HTH,
    Sebastien
    This is a test
  • Hi Sebastien,
    Thanks for the reply, There are some features listed in the dropdown list but I noticed that the features that are listed are DGN XFM features and it does not include the database features. I also noticed in FEATURE column beside the OPERATION column, all the features are listed in the dropdown list.
    Please Help
    Jun
  • Hi Jun,
    It exists two kinds of properties here: Operation Properties and Feature Properties. In the property watcher tab, you must define which properties you watch. So you must define name of FEATURE or OPERATION first, then type the name of property to update.
    There is from Bentley Geospatial Administrator help file:
    Property watchers allow one or more properties to watch for changes in the source property. When added to a property (the source property), each time its value changes the related properties are triggered to respond.
    A property watcher watches for a certain value in one (source) property which then determines an associated pre-defined value in another.
    The property watcher´s metadata define one or more properties that are dependent on the setting of the source property.
    Feature: Double-click this field to select the feature that contains the property to update. This should be left blank if the property is an operation-based property.
    Operation: Double-click this field to select the operation that contains the property to update. This should be left blank if the property is a feature-based property.
    Property: Enter the name of the property to update. At the bottom of the tab Define Property Watchers, the details of the property watcher display.
    Finally, on my side, database features (from ODBC Access or Oracle Spatial registered feature) are listed in feature column.
    Sebastien
    This is a test
