I have defined in a GSA Date Time Property for editing purposes, it stores the date and time in a format "dd/MM/yyyy HH:mm:ss". If it is a XFM property everything works fine, date and time updates while I am editing the feature. Problem has occured when I've changed it into Database Property connected to MS Access database via ODBC, now while editing only the date updates but time has constant value of 00:00:00. Does anybody now what causes this behaviour? Maybe it is a bug?
GSA version: 08.11.07.86
Please help,
Best regards,
Peter
All questions about Microsoft technology. If the DB supports hybrid date/time and ODBC supports hybrid date/time, then there's a chance that XFM can support it. If either the DB doesn't support hybrid date/time or ODBC doesn't support hybrid date/time, then you're hoping for too much of XFM.
Problem solved. This is the answer.
Thank you very much for your help,
what is the value format?
%#m/%#d/%#Y %#X
