Hello
We have recently upgraded lots of dgn files to V8 form VJ. A lot of these files have raster attached to them. We use a small web viewing program to view drawings online.
To view these drawings with raster attached correctly we have to reattach the raster using Raster Manager in Microstation V8i. I was wondering if there was a bulk way of reattaching (not reloading as this does not work) all the rasters using the bulk process.
First I have to detach all of the rasters which is easy (Raster Detach All). I want to know if there is a way to set up a csv file (or something simular) so I can use the attach option (raster attach fixed <filename>) but changing the file name with each drawing. We have set it up so that the file name of the raster is the same as the dgn but with a .cit extension.
Thank you Mathieu. That has helped us a lot.
