Hi all,
I was having trouble with joining tables (sometimes working with other table, sometimes not) I hope someone could help me this;
I was joining two feature tables together (Oracle database properties not Oracle spatial) using Bmap join capability but it was unfortunate to me that i was not able to get result out of the join.
Both two tables have a common column fields and values, although during the process it successfully joined but when I analyze the result the additional columns and values are missing. To make sure that I dont have any problem with my setup, I tried joining the table using the old joining process in Visual Query Builder and it works. I also noticed in the Data browser the column are there but with empty values.
Wondering how is this happened.
BM 08.11.07.113
Jun
Hi Jun,
Can you said what is origin of your second table (oracle, shp, dgn xfm, etc...) ?
In which do you join table ? I mean here which feature property is on left side and on right side ?
Once joined, are you able to see properties values in analyze window ?
Please send me the complete request text (Landuse.OID = ECPK_LANDUSE.OBJECTID) ?
Thank you!
Sebastien
Finally, it seems to be a known issue. It was internally filled as Trouble Report (TR# 273696).
HTH,
Hi Seb,
Thanks for the reply, I hope this will be fixed very sooner, its so frustrating that I could not deliver to my client what they want. I can rather use the old Geographics than this Bmap in terms of Thematical presentation with several tables to joined.
Thanks anyway
