Hi
I wonder why "Fence Delete Clip" does not works. I get a message "No Elements Found"
Second I wonder why "Fence Copy to File" and Fence Move to File" strip of the features informations from the graphic, so the files are plain microstation files.
Is that a "Works as Designed" or will that be changed in an upcoming version of PowerMap / Map ??
Erik
For feature continuity, there are certain standard MicroStation tools that are not honored by features during graphical manipulations. Some of the fence, copy, delete, file operations fall into this category. This is definetly a WAD. Other tools behave differently thaan what you would expect, thus the fence copy to file and the fence move to file. These behave differently based upon where the non-graphical data is stored.
HTH
Jerry
...and in the upcoming Bentley Map V8i (SELECTseries 2) release, the FF= and SF= commands will in fact transfer XFM feature instances along with their business properties.
Jeff Bielefeld [Bentley]
