Hi all,
I have setting up our project in Geospatial Administrator using an Oracle database which currently working now, but the database administrator adviced the GIS Dept to transfer to another database. What shall we do for us to use the same project schema with another database?
thanks
Jun
In the XML file there is a database tag.
Example for a ODBC connection :
<Database type="ODBC" name="eastcity1" genFile="database.xml">
<Tables>
<Table name="intersect">
And for a Oracle connection :
<Database type="Oracle" name="geoCimOra11" genFile="database.xml">
<Table name="ns_milepost">
Change the name there. Make sure you backup the original before making these edit changes.
Also make sure you do a update on the Database node, in the GSA, just to make sure you have made the change correctly.
HTH
Jerry
What XML file am i going to edit? and what editor do I use to edit the XML? Can I use notepad ? or any editor you can advice.
you are editing teh same XML file that you are editing in the GSA. Using any standard text editor or XML editor will work.
