Hi folks,
as Geographics with MSTN 2004 probably damages dgn file using Thematic resymbolisation function I tried to use Bentley Map. I created Map model in my working file and attached a model with shapes created from original map. All the shapes has database connection according to feature table. I can not find where I did a mistake - when I try to use Thematic Mapping I do not see database atributes when I try tio create new class in Symbology dialog box. Can anybody provide me tipe where I shoudl have a look? I searched through help but did not find anything.
Thanks for help,
Jiri
Could you please provide versions of the current software you are using ?
In general, make sure you have connected to the database containing the attributes before you open the dgn file. Otherwise, Bentley Map will not be able to obtain the attribute values. You can verify if Map is able to read the properties by using the Data Browser.
Depending on the symbology class type that you are creating (if you are using a symbology generator), you may need to choose a numeric property type.
