Does dgn2sdo run as scheduled task ?
I've set up a batch file mytask.cmd
containing several lines like
dgn2sdo ...
call masterload.bat
dgn2sdo ...
cal masterload ...
It runs pretty well if I activate it in a console window, but I'd like to run it as a scheduled task when most users are offline. But the first dgn2sdo job just creates the output folder and then the task seems to loop forever. It is still running after hours without consuming any ressources (cpu, memory), while it takes about 30 min in an interactive session. There is no input needed so I've no idea why it is waiting.
 Holger
  • In the past I have ran this as a one time operation and not re-ran it on a schedule. This is becasue you are using this to dump dgn data into the database and then not using the dgn files again. Each time you run it, you will be dropping and deleting all your Oracle spatial data and then re-creating it. Thus changes in the tables, between each run, will be  lost, unless you have edited the sql scripts created by dgn2sdo to not drop the tables, which sounds unlikely.
    You may have to add some additional parameters to the sqlplus and sql loader to have it not run in console mode or you may need to edit the masterload.bat file to accomidate what you want to do. Either way it does not sound like you are going to be able to automate it the way you want.
  • Jerry,
    thanks for your response.
    I've covered the sql loader stuff already by creating my own "masterload" script which runs perfectly within a scheduled task. I've actually removed the masterload calls to  execute only one dgn2sdo call, but the result stays the same. It looks like that dgn2sdo doesn't work out within a scheduled task. dgn2sdo looks  as if it is just a batch process like "ustation -wa..." which works perfectly for other mdl progs we have, but somehow this tool doesn't work.
    My question is now, can dgn2sdo run in scheduled tasks or do I have to reinvent the wheel and create a "task-enabled" tool on my own?
    regards,
    Holger
  • Hi. Can you look at the output of your batch file and see what's wrong / where it blocks ? This may be related to security / rights. Could you ensure that you are running the scheduled task under a user account that has the right priviledges ?
  • Martin,
    I tried to follow your advice and found the script to run under the same user on other machines (XP, W2K8), though it seems to be a machine/os dependend problem. In case it doesn't run, the process does no output at all, it did start microstation and the dgn file is locked, but only the output folder is created. While the whole process needs only a few minutes in interactive mode (for one dgn), the scheduled task seems to last, I aborted it after 20 minutes.
    Do you know a good trace tool for tracing this?
    regards,
    Holger
  • Martin,
    the following output is from a machine where it fails.
    DGN2SDO 8.11.7.113 will be running with MicroStation version (08.11.07.171).
    02.02.2011 16:21:15
    Effective Workspace Home = (C:\ProgramData\Bentley\MicroStation V8i (SELECTseries 1)\WorkSpace\Projects\Examples\Geospatial\defaults\)
    Created Dynamic Feature Scoring rules file at: (C:\ProgramData\Bentley\MicroStation V8i (SELECTseries 1)\WorkSpace\Projects\Examples\Geospatial\defaults\xml\features\dynamicScoring\DGN2SDO_FeatureScoring.xml)
    Output directory has been set to (c:\temp\r01_00)
    Loading Bentley Map
    Opening design file "C:\temp\test.dgn"
    Obtaining instance cursor
    Commencing translation
    ERROR: Error encountered while translating instances = (The Property 'DGN_ID' is read only).
Reply
  • Martin,
    02.02.2011 16:21:15
    Loading Bentley Map
