Holes in shapes do not work when importing from shapefiles
Hi all
When we import a shape file into Bentley Map SS1 holes are getting "filled".
A simple test:
See the attached dgn file.
1) On level "Original - with hole" I have made a simple shape with a hole.
2) I then export it to a shape file. And checked that it is exportet correctly (it is)...
3) Then I import the shapefile again - the result can be seen on level "Importet - no hole" - and now the hole is gone...
Is this a bug or a feature? Or am I missing something?
Kind regards
Morten
Hole_test.dgn
