Hi all
When we import a shape file into Bentley Map SS1 holes are getting "filled".
A simple test:
See the attached dgn file.
1) On level "Original - with hole" I have made a simple shape with a hole.
2) I then export it to a shape file. And checked that it is exportet correctly (it is)...
3) Then I import the shapefile again - the result can be seen on level "Importet - no hole" - and now the hole is gone...
Is this a bug or a feature? Or am I missing something?
Kind regards
Morten
Hi
Martin - sounds promissing :-)
Jerry - no I have not contacted Safe.
Martin,
is SS2 still timed for "early Q1 2011" or is there a new ETA for it ?
Holger
Yes. In fact, it should now be available.
Tried this hole_test_jaw.zip example in SS3 and it now creates new version XFM Feature which also acts weird. If I map to a feature without fill then it is not possible to select polygon collection it selects only individual shapes.
Yes, there is definitely a sweet spot for the collections. We have to be able to modify the individual components of the collection AND the collection as a whole.
If you select the outer edge of one of the polygon components then that component is moved, etc. If you issue a datapoint on the interior of the polygon then the collection will be selected and the whole collection can be moved.
Is that what you are looking for ???
