Bentley Map Enterprise (SS2) and Oracle 11g
 I have been playing around with Bentley Map Enterprise v8i (SS2) with our Oracle Server.  The tables on my Oracle server are built from MapInfo TAB files (using MapInfo EasyLoader Utility), and a script is run to fix the SRID and USER_SDO_GEOM_METADATA, so that BM can work with the tables.
For some reason BM isn't recognising my geometry types correctly.  In the "Interoperability" dialog, it says every table has a Polygon Geometry Type.
I have checked the Geometry column, and the SDO_GTYPE seems to be correct.  What else do I need to check?
Thanks Ian
Parents Reply Children
  • Fantastic ! Now look at the Spatial Index as Martin has suggested. For the different feature types we typically set them as follows:
    Point
    CREATE INDEX VAULT_GEOM_SIDX ON VAULT_GEOM(OGC_GEOMETRY) INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('layer_gtype=point');
    Linear
    CREATE INDEX CONDUIT_ROUTE_GEOM_SIDX ON CONDUIT_ROUTE_GEOM(OGC_GEOMETRY) INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('layer_gtype=curve');
    Polygon
    CREATE INDEX L_SUBMAP_SIDX ON L_SUBMAP(OGC_GEOMETRY) INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('layer_gtype=polygon');
    Jerry
